61 - 80 of 101 Posts
Gold Founding Member
Unlikely to work in this particular case.
You're suggesting that he cram male straight threads, intended to be sealed with an O-ring (O-Ring Boss style, ORB) against a tapered O-ring pocket machined into the casting, into female tapered pipe thread with no O-ring pocket.
Incompatible threads, incompatible sealing methods.
At least, I expect the OP has pipe thread at the inlet, and both outlets.
Reactions: 71malibuu
Looks like a reduce coupling to go from the -6 to the -8 looks like hose. On a side note I’m surprised that more people don’t use 1/2 in or 5/8 aluminum soft roll for fuel line.
1969 El Camino SS396
I've used regular white teflon tape for 40 years or more. Make sure you wrap it the right direction and put 3-4 wraps on the fitting. Also, the tape should only be on the threads, not across the open end of the fitting. No leaks with a carb or EFI.
Discussion Starter · #65 ·
Well the Gasoila sealant seems to have done the trick, I'll post a pic of the fitting too
Light Product Blue Bicycle fork Automotive tire
Finger Thumb Nail Gas Automotive tire
Well the Gasoila sealant seems to have done the trick, I'll post a pic of the fitting too View attachment 721132 View attachment 721133
The inlet fitting appears to be a tapered pipe thread fitting, screwed into a tapered pipe-thread hole. There's male threads visible, because male pipe thread should never screw into the hole so deep that the threads disappear.
The outlet fitting in your hand appears to be straight thread, screwed into what is almost certainly another tapered pipe-thread hole. Incompatible threads, possibility of damage to the female threads.
Good luck.
Discussion Starter · #68 ·
So I need a tapered AN fitting? I mean tapered on the threaded side not the AN side, same type fitting on the other hole
Almost certainly.
I'd expect the inlet and the outlet holes in the casting to be threaded the same. It's not impossible that they aren't, but I think it's extremely unlikely.
Discussion Starter · #70 ·
I have a couple pics but I don't think it's possible to tell from the pics? it's a fairly new Summit reg., I'll give them a call to see what they say and order what's needed, don't want the car going Up In Smoke...or Flames
Automotive tire Bicycle part Motor vehicle Engineering Gas
Camera lens Camera accessory Digital camera Film camera Carbon
Camera accessory Cameras & optics Gas Automotive tire Auto part
Discussion Starter · #71 ·
I just noticed the small threaded hole to the R of where the outlet fitting goes, should that be capped? never even noticed it before
Do you have the part number? I just did a quick look at Summit’s site at all the Summit brand regulators of that style, and all of them list a 3/8 NPT fitting for both inlet and outlet.
I have a couple pics but I don't think it's possible to tell from the pics? it's a fairly new Summit reg., I'll give them a call to see what they say and order what's needed, don't want the car going Up In Smoke...or Flames View attachment 721240 View attachment 721241 View attachment 721242
Discussion Starter · #73 ·
It would be over with the car in a receipt folder, I'll take a look for it tomorrow, I have 2 other regs there that I'll take a look at, can you tell with a caliper in the threads?
If you measure the threads, an NPT thread will be tapered and the female side will be larger at the opening and smaller on the inside.
Reactions: shovelrick
Discussion Starter · #76 ·
Well I guess I'll be calling the local speed shop Gear Head Perf. mon. to see if they have the correct fittings in stock, no wonder it kept leaking before, I'm not waiting for the Gasoila sealant to leak then say it DID NOT seal good
1965 El camino. Originally roman red with a 283 and rear air ride suspension
Discussion Starter · #78 ·
Yellow tape does say gasoline, I might have the wrong fitting in my case
First Guess: A vent that allows the diaphragm to move without restriction. Needs to be open. CHECK YOUR PAPERWORK for confirmation.
Didn’t know this
The taper rate for all NPT threads is 1 inch of diameter in 16 inches of length
An experienced eye can see the taper in tapered pipe thread. Newbies generally can't...at first.
Not all pipe thread is tapered, but I can't remember the last time I worked with non-tapered pipe thread--it exists, but it's not common. So again, you've gotta use male tapered pipe thread with female tapered pipe thread, male straight pipe thread with female straight pipe thread, and then there's metric pipe thread, and British pipe thread, and fourteen other variations. Enough to make a guy crazy.
That is what I'd expect. HOWEVER, I can't be certain by looking at his photos.
I am moderately sure that the rough casting has a taper leading into the hole--for ease of machining the threads on fast-paced automated thread-cutting equipment. I think the female threads are tapered, but that could just be the angle the photo is taken at.
MAYBE that taper leading into the hole is for an O-ring seal. I don't really think so, and it would mean that the threads have to be straight, not tapered. And, it might be that what I'm seeing is damage from using the wrong fitting.
Best to find out directly from Summit, based on his actual part number.
