Hello,
I wouldn't normally post a question about a car as unimportant as this one, but I have been working on it for two months now with no success. I know some of you guys are really knowledgeable so I figured why not give it a try.
Timing Belt: 1995 Chevy Monte Carlo 3.4L DOHC Z34 V6
I removed the timing belt like a complete idiot against my better judgement. Now I have a problem. I got the crank and balancer lined up... I think I have the first 3 cams lined up right. Originally there were yellow dots on all 4 of the cams. I went over 3 of them with a little white paint, and then lined up, one facing the next. The fourth cam,... the all the way towards the back of the engine, is so dirty and corroded that I can't tell where the dot is, and therefore cant line up those two cams towards the firewall. Now what??? Went on monte carlo forum and the only info I was give was to "line up the cam flats." Honestly not even sure what that means... and if they mean line up the cam dots well we're back to the same problem. This is a mess...
1. How do I get the four cams lined up properly.
2. If infact the cams are lined up dot to dot, how to I get the other two lined up when one of the dots are not visible.
Any help you can give me I will appreciate,
Dan
Dan
