1 - 10 of 10 Posts
· Banned
Will I be able to get 500hp\500tq & keep it under 6000rpm?
Here's what I will be working with.
AFR 190's
RPM with a Qjet
Leaning toward a hyd. roller
looking at SRP pistons with a 16cc reverse dome, they put it at about 9.4-1
6 inch rod & probably Scat 9000 crank
I like too have the hp peak 5500-5800. Does this sound like too much to ask for?
Don't even worry about HP in a street engine. Go for the most torque starting from idle. If you can make 500 Ft. Lbs. @ 4500 RPM, you won't care that you don't have 500 HP.
If you didnt mind running a solid flat then I think you would really like the current cam I am running. It has great street manners and runs good at the track. Mine peaks power right in the range you are looking for......
XS274S......274/280 adv....236/242 at .050.....534/544(1.6's)......110 LSA
· Banned
I know what you mean Ken, just threw the 500hp number in the mix.
· Banned
Don't mind the solid flat deal but I kinda wanted to go with a hyd. roller & give it a shot.
Anybody tried the XFI lobes from Comp? Thinking if you got one tightened up to 110-111 instead of 113 they might do better with a carb.
Yeah I talked to Mike Lewis about them for my car. He said they would work well with the lsa brought down to 110 on my motor. He liked the XFI-280.
9.5:1 406 with... stock 400 heads (1.94/1.6) home ported,5.7 rods,stock crank (.010/.010),and a 280H CompCam,750dp Holley,with a Vic Jr. intake, in a 3450# car,th350 (3000 10" stall)and 2.73's (not a typo) went [email protected] 3.73's went [email protected]
New heads (200cc Protoplines) bumped compression to 10.2 went [email protected]
All on 91 pump gas and driven everywhere.
1 - 10 of 10 Posts
