1 - 20 of 56 Posts
Thought it would be cool to have a spot to reference in regards to getting these cars out of the gate.
What's your best 60'? >:)
Provide:
Weight
Engine/trans combo
Shock type (front rear)
Suspension type (components used)
Tire size/Type
Personal: I don't have one for a chevelle.. just mustang, but I do plan on beating my old best.
Old 90 Mustang
Weight: 3115
Combo: SBC/NOS- Glide
Shock/Strut: Strange single adjustable front w/ coil overs | Santhuff dbl adjustable rear coil overs
Suspension (stock bolt it): Front Racecraft tubular k-member and a-arms, rear: all wolfe race craft dbl adjustable w/ dbl antiroll
Tire size: 275/60 hoosier drag radial.
Best 60': 1.14 (back in 2012)
Weight : 4050
bbc 540,turbo 400
qa1 double adjustables on all 4 corners with drag springs on the front.
stock a arms up front with arb on the rear.
hoosier quick time pros 29x11.50 15ns.
3:73 gear with detroit true trac. gm 12 bolt.
best 60' is 1.50
1/8 mile best is 6.61 at 103.
best 1/4 is 10.36 at 129
all in vegas off of idle and a foot brake.
10.5:1 pump gas 91 octane 406 The pass in my sig coasting through the traps.
3550 with me in it all steel,glass,interior and full exhaust
Caltrac's/split mono's with Santhuff front springs 275/60/15 MT ET pro's with a 6 sec burnout.
off idle, 1.45 60'/6.75 1/8 @ 100 mph / 10.69 @ 122.3
weight; 3550 w/me in it
496 NA / 400 turbo
Calvert shocks front and rear
cpp upper control arms stock lower with Moroso springs. Cal-tracs w/Durant mono leaf 3"drop rear springs
M/T 295/65R15 radial
best 60' 1.38
1/8 mile 6.40 @ 108.10
55 Chevy
69 Chevelle SS
3800 w/me in it.
454/TH350
Front suspension stock w/Monroe gas mag shocks, stock sway bar.
Rear UMI Round trailing arms w/poly bushings, adjustable uppers, Lower relocation brackets and Monroe gas mag shocks.
M/T 28X10.5 slicks
6/20/2014 was my last track outting
Best 60' 1.65
Best 1/8 7.56 @ 89.8
best 1/4 11.96 @ 110.6
Hoping to best my time soon with a new 700R4
My old car was a 70 Chevelle:
Backhalf , ladder bar with double adjustable shocks and 138 springs.
Stock front end with rubber bushings, Single adjustable shocks with Moroso 250 trick springs and travel limiters.
3180 with driver last time it was weighed
565 with t-400 and 4.33 gears with 16X32 Goodyear D-5 stiff sidewall slicks.
8.877
150.98 mph
1.212 60'
'70 Chevelle
weight, 3600 w/me
zz383 / 700r4 / 3.55
old parts-store shocks F/R
(4) Hotchkis springs (1" lowered)
Hotchkis front upper-A-arms, poly bushings
Stock rear suspension, poly bushings, no arb
MT ET Street 26 x 10.5
Footbrake to 1800-2000
Best 60' 1.63
Best 1/4 ET / MPH 12.18 @ 109 (-69ft DA)
-Dave
Weight: 3,425
Engine/trans combo: SBC/TH400, no transbrake
Shock type (front rear): Comp 3 way adjustable up front & Afco dbl adjustable
Suspension type (components used): Calvert split mono's & Caltrac bars
Tire size/Type: 29X12" Hoosier bias ply slick
Best 60': 1.36
Best 1/8: 6.07 @ 116
Best 1/4: 9.56 @ 143
Boldly procrastrinating
this would be a good thread for cabin fever season next winter. Just IMHO, YMMV, etc.
Reactions: 427L88 and p40
We don't have it in Phx either but it's been shown that a large percentage of the country does.
468, TH400/10" 4000 flash convertor,3.31 gear, 3,945 lbs. w/me
100% stock front/rear suspension.No trick springs ,parts store shocks, no traction aids-nada
Best 60 ft. 1.69 on Hoosier QT Pro 26x9.5
Best 60 ft. on Polyglas G70 1.95
Provide:
Weight
Engine/trans combo
Tire size/Type
Old 90 Mustang
Weight: 3115
Going to have to ask for a timeslip on your claim.
My bud runs a 99 Firebird, 425 LSX twin turbo, on the corn, runs consistent 7.30s @ 194.
His 60? 1.15 on average. And that is breaking the 60 on the back tires. Roughly 7 feet added to the 60 foot.
Discussion Starter #14
I'll have to dig it up, but I'm honestly slow to the 60' by any account in the racing circles I'm around. Look up X275. The most impressive car I know of is Ron Rhodes' 68 camaro. SB/NOS car on leafs, on a 275/60 is consistanly sub 1.10, and I know he's been 1.04. But MOST competitve X275 cars are 1.10 or below consistantly.
Here's a video of my car from years ago in the mean time. It's a [email protected] to the 1/8.
Discussion Starter #15
Scroll down a little bit, this is the Snathuff site. There's a time slip posted from Ron's car. a 1.05.
https://www.santhuffshocks.com/newsarchive.html
2900 lbs, 302/4v, C4, 1.77, 7.79/84. All motor 82 Mustang. On a 7.5 in rear axle and 275/60/15 BFGs. Footbraked and manually shifted. Stock rear suspension, with boxed upper and lower arms, air bag in the right rear and with the stock sway bar installed. Cut four banger front springs and no sway bar. Slightly quicker when sprayed. At Savannah Dragway in 05.
496, glide, 8” converter, 4.88’s, 29.5/10.5 PBR’s, ladder bar/coilover in rear, stock replacement KYB shocks and 250# rate trick springs in front, 69 malibrew 3700 pounds, goes mid-hi 1.4’s, best of 1.41 (1.41 was on 28/10.5 pbr)..
1 - 20 of 56 Posts
