Recent home rebuild, standard automatic valve body
In Drive - stuck in 1st. Will not shift to 2nd unless I pull down to L1 and back to L2
In L1 - drives fine
L1 to L2 - Will shift into 2nd and drive fine
L2 to D - Will not engage 3rd. Stays in 2nd
P and N fine
R drives fine
Air checks during assembly seemed fine. Clutch packs engaging.
Kick down solenoid checked prior to install (applied 12v and heard relay clicking... other possible failure mode here?). Currently not connected in the car (no wire connected).
Linkage adjustment fine
Fluid level fine. Full mark verified.
Going to check modulator, vacuum signal,, and then governor. Mind you this transmission would shift VERY early prior to rebuild and in D would hit 3rd before crossing an intersection. I have not calibrated the governor yet, just reinstalled as is.
If that yields nothing, I guess I will get a pressure gauge connected (do not have one at the moment), see what I have, and lastly pull the valve body if necessary.
Anything else I should be looking at?
In L1 - drives fine
P and N fine
R drives fine
