I'll check that tonight thanks...Are you getting 12v + to the kickdown switch on the other side of the trans when flooring it? If not, there´s your problem !
Fix that crack as car will not upshift properly with a leak there. It will stay in gear too long at normal acceleration if there´s a leakage.
