Last fall, I had my Turbo 400 rebuilt and the transmission is performing the way it should. After the rebuild, I noticed a very minor leak (literally one drop per week) which appeared to be originating from the pan gasket. The pan is tightened down to the point where torquing the bolts any more will start to distort the lip on the pan.
For the past 2-3 weeks, the car was not used. When I pulled it out this past weekend, I found a puddle of trans fluid amounting to maybe a 1/4 pint of fluid. Someone suggested that after sitting that long, the torque converter drained down, resulting in the puddle. Prior to the rebuild, the car sat for extended periods and I never had a problem so why now.
Inspection of the underside shows no obvious leaks, other than a wet edge on the pan gasket. Anyone have any insightful ideas of why the leak after sitting?
