Im putting my car back together after a motor swap and forgot which transmission cooler line on the radiator goes into which fitting on the transmission. Does it even matter?
Central Iowa
If already pre bent new or your used lines, hooking them to the tranny will probably
tell you which line goes where. Look at where they end up at the bottom of where
the radiator is or will be installed.
Not sure if it the top or bottom line at the tranny is the return line.
Hope this helps
Sir,
Upper to Upper. Lower to Lower.
Trans Upper is the return / in. (From top of Rad)
Trans Lower is the feed / out. (To bottom of Rad)
Mike
Reactions: jeffs68
Thank you all!
