I have a 67 chevelle with a TH350 that was working fine,but drove it the other day and it wouldn't start off in first just second to third, other times it starts off in first and skips second and goes to drive, if I put the lever in first and shift manually to second and drive manually it does fine. I replaced the modulator valve with no help,also hoses. Any ideas ? Thanks
Pull the governor to check if the valve inside is sticking. Hold the gov. with the gear up and move the weight's in and out and watch the valve inside and see if it hang's up. And also check the condition of the plastic gov. gear. C-ya Scott
Thanks for the help,did seem to be stuck,only problem is the spring holding the cover broke anybody know where to get a new one and also gasket for the cover? Thanks Kelley.
