I purchased a Summit brand 2000 stall torque converter off the clearance shelf at summits head quarters awhile back . I recently went to install it and noticed it had fluid in it already. It looked fine so I went ahead and installed it. When I filled the trans and fired up the car, it was making a light but noticable tapping noise while idling. After removing the trans inspection cover and starting the engine, I realized that the converter was wobbling and looked to have at least 1/2 inch run out and the noise was coming from the converter
. I immediatly shut the engine down. I did not drive the car at all like this, and only ran the engine on and off for 5 or so min to locate the issue. The trans did engage in all gears with the bad converter.
Thinking back, it did go in kind of hard. i had to tap it 3 times with a rubber mallet to engage the pump gear, and lightly pop it forward with a pry bar to bring it up to the flex plate.
I went to summit and bought a new Summit 2000 converter, and removed the defective clearance summit converter. I installed the new converter. It almost went on too easy
. I did verify that the pump gear tabs were ok prior to installing the converter, and even indexed them at 3 and 9 o clock position to aid in converter installation. The Gear rotated with no issue using a pocket screw driver when I was aligning the tabs at 3 and 9.
I finished installing the trans tonight, added a total of 6 qts to the pan through the dipstick tube, first four, then two more when I had no gear engagement. After checking and rechecking the fluid level, I determined the pump is pumping zero oil. This was verified by cracking a trans line loose at the radiator, then starting the engine and having a helper shift the trans to drive with the engine running.
I picked the car back up on the lift, dropped the inspection cover, unbolted the converter from the flex plate, and easily slid it back to whithin 1/16 inch from the bell housing. The converter felt like it fit very losely when engaged in the front pump, I could wobble it by hand about 3/8 of an inch. I compared this with a known good fresh spare race trans and converter I had, they were nice and tight with very little play. I am thinking I damaged the front pump when i ran the engine with the defective converter. Any opinions on how bad I tore it up. Pulling trans out AGAIN
:sad: tomorrow and removing pump. Contemplating getting a fresh pump assembly vs possibly replacing a couple parts.
By the way this is my better halfs car who is 9 mos preggo and due next week. She wanted to drive her GS one more time to a local cruise this friday before she is busy for the next couple monthes. I am still hoping I can Pull something out of my a$$ and have it going for her by this Friday.
