I have a 68 with the clock out for testing and replacing the adj. pin. It wasnt working and I found one of the wound wires broke and resoldered it. now when I apply 12v to the back spade and ground the body it makes a sound as if a contact was opened but nothing is moving. should something move? thanks
Depending on who made the movement, Borg-Warner or Westclox. I think it's the BW's that have a "flyback" lever. When it ticks down to where the contacts close, the electromagnets energize, and this weighted lever "flys back" up, winding the spring for another minute's worth of ticking.
A lot of times the contacts get burnt from the severe arcing over 30 years. You can manually (gently) move this lever up, and the clock should start ticking again.
"Atomic Batteries to Power...Turbines to Speed"
(The Minnesota John D)
'64 El Camino
383 - TH-350 - 12bolt - 4wh pwr discs
Bedded down for the Winter.
[This message has been edited by John D (edited 11-25-2002).]
