If it is a standard cylindrical coil, a typical value between the neg and pos post should be between .8 ohms and 4 ohms. There should be about 6K-15k OHMS between the positive terminal and center (HIGH TENSION CONNECTION)
http://autorepair.about.com/od/troubleshooting/ss/coil-test-ohm.htm
Blaster coil:
The blaster SS specs are as follows-
.355 ohms on the primary side [(+) and (-) terminals].
4.4k on the secondary side [(+) and coil tower]
HEI:
Between B+ and C- reading 0.4 ohms
Between C- and high tension coil output - readings infinite.
a blue spark from coil tower to positive terminal what's wrong?? I get a shock from wire from wire from Distributor to Coil. Why?
