Gold Founding Member
I picked up a motor that has a 65 Chevelle PN. It was supposed to be good but I can't get it to run (my 64 harness won't fit so I can't test in in place). I ground the chassis and try 12V to each of the leads and nothing happens. I seem to recall when I converted my 59 pu from vacuum to electric using a 65 PU motor it took a combination of power to the leads to get the two speeds to work. The motor and transmission gears turn freely so its not bound up. Thanks in advance. Patrick
