1 - 2 of 2 Posts
Is there a correct procedure to check my windshield antenna? Is it just a matter of ohms checking? I suddenly have a lot of static interference in the radio. I temp installed a mast antenna and it sounds good. I'd like to be able to isolate the windshield portion & the lead in from antenna to radio. Thanx.
Might be able to check out the antenna cable from the firewall to the radio with a meter. The antenna is only a couple of strips of wire in the window. If they are not cracked and the lead soldered to the window is OK, not much else to check.
1 - 2 of 2 Posts
