Hey guys, I have a 67, and I need to know how to check a neutral safety switch. Also, is there supposed to be 2 wires on the positive side of the coil? One coming from the solenoid and the other from inside the car?
I need to know this because I cannot start the car. I just bought it, and the wiring is a mess!!
Administrator
Yes on the 2 wire to the + side of the coil. With your shifter in P or N use an ohm meter and check continuity between the two terminals on the NS switch (Purple wires). If you don't have continuity move the shifter a little both ways and check. It may be out of adjustment.
Awesome, thanks. I will try that and report back!
