When I turn my head light on my Temp Gauge goes all the way to the right. I have replaced all underdash harnesses and have a new headlight switch.
Thanks for the info Phil. There use to be a tech ref. as to where the ground points should be for the dash gauge. Do you know where that link is or do you know yourself where they are. Any help from anyone would greatly be apreciated. Thanks again Rodger
No I dont know where they go exactly I just attache mine to the cowl area with exsisting screws. Probably not right but thats probably why my AMP gauge isn't working
Philip Mullaly
72 TPI El Camino
You can never fix a Ford,You can only work on them alot.
70 442
The Z-meano
Cowl induction injection
