'72 el camino. changed bulbs, cleaned connections, but no right side tail light. brake light works but neither the little marker light (194 bulb) nor the tail light element in the large bulb works. assume i need to start chasing back the wire. does it crossover above the bumper from the left side? or what?
Earlier years did cross under the car. Haven't spent any time crawling under the 72 I bought but can do that if you don't spot them.
thanks but i found it tonite. wire was broken coming out of the left side. i changed a gas tank and a rear bumper a little while ago. i probably disturbed that 30+ year old wiring when i did that. i should have known that after something gets fixed, spend an appropriate amount of time inspecting for what damage you have done in the process. at least that rule applies to me, not speaking for everyone here.
