67 Chevelle Original Right & Left Tail Light Housing Rear Quarter Extensions. They have been bead blasted and cleaned of all prior paint. Both suffered slight damage but have been repaired. The passenger side had a crack on the outer edge that has been welded close, body filler applied and is in ready to finish condition. All mounting studs are intact. The driver side had a small section broken out which was mostly covered by the chrome taillight bezel. It has been repaired with a new section welded in and also final finished with body filler. It had two broken mounting studs which were drilled, tapped and 1/4x28 threaded studs inserted. Both are in bare metal condition so repairs can be observed, no hidden issues. Repairs and finished condition can be seen in the attached photo's. Both would need only a final touchup, primer and topcoat paint.
