Hello, I am having issues with my 1969 Chevelle SS. My tachometer is malfunctioning after short run times. The issue is that the tachometer works then stops working then once again seems to be fine. This occurs all while driving a short distance. (couple miles). Then it just completely stops working.
Should I look for a connection problem or ground problem?
All other instruments in the cluster are working just fine. Only the Tachometer is the issue.
Has this issue occurred to any other user?
Are their any links to this issue?
Thanks you,
Rocco _ user: 69396375HP
Thanks you,
