I have a 72 ss with warning lights. I want to replace my broken gas gage with a repro tach. Which printed circut board do I use? Mine is broken anyway. Can I make the switch using the routing on the board or will I have to cobb it together?
I'm not sure of the answer. A guess would be you need to add individual wires to the repro tach.
I'm with John on this one. Even if you used the power and gnd from the circuit board you would still have to add the wire to coil. It would be much easier to just tap into the wires going to the gauge cluster or run them to the fuse box.
My 70SS
