I have a frustrating problem on my SS454. The original factory tach is reading RPM speed twice the expected amount. Any suggestions or should I just replace the tach with another one I have on hand? I was thinking maybe it was a simple wire connection problem or perhaps a bad circuit board on the back of the dash cluster?
1970 SS 454 Hardtop
1970 SS 396 El Camino
1970 SS 396 Hardtop
1986 SS Choo Choo Elky
TC Gold #155
chuck...you might check with the clock doc at 1-800-256-5362. they restore clocks or will convert to quartz. they also restore tachs. i highly recommend them.
hairy
66ss396 marina blue A.C.E.S #124
walt's 66 SS.COM
What ignition system are you using, original points or HEI or ?. Sometimes the factory tach won't work right with aftermarket ignitions.
My 70SS
you may need to do the HEI mod on your tach, or could possibly have problems with a ground. Doy LeCroy is just outside of Mesquite and specializes in tach repairs, email me if you need a phone number
I'm in Garland TX, and I also repair tach's.
My 70SS
[This message has been edited by Steve S (edited 02-21-2001).]
Thanks for the input guys. I am running stock points and condenser. I think I will try one of the other factory tachs I have and see if one of them works correctly and if not, I know I have a wiring problem. If one of the other tachs works OK then I will get the one in the car repaired as a back up.
1970 SS 454 Hardtop
1970 SS 396 Hardtop
TC Gold #155
