wired in tach appears to work fine after about 5 minutes engine dies. only way to start engine is to disconnect tach wire from hei tach connection. are some tachs not compatible with hei, tach bad or hei problem. tried it several times same results, when tach wire is disconnected for a minute engine stars right up.
wired in second tach same results only engine started missing bad before dieing
