I have a '71 SS with full gauges, although the tach, amp and temp gauge aren't working. Is there any way to test the gauge itself to determine if it's the gauge or something else causing the problem?
Does the fuel gauge work? Sounds like you are missing gauge power, check fuse box. If not make sure all the ground connections are good. It is not likely that all three gauges are bad. When I get home tonight I can give you details as to which traces/pins to work with to check each one out.
My 70SS
Discussion Starter #4
Fuel gauge does work.
