High all, first post here. I just had my trans rebuilt and it wont shift into second or third, it has a Hughes manual valve body in it. It goes into reverse and first fine but when I shift into second it slips and third does the same thing. I dropped the v/b out to apply air pressure to that 12 point bolt in the case, I could hear it clunk inside but could also hear air by-passing in the case, I have been getting conflicting reports as to whether this is acceptable or not. I did check to see if the manual valve was properly indexed and it was, the shifter is properly indexed also. Do I have a bad lip seal? Do I have to remove the trans and tear it down again? What should I look for when it is opened up, as I do not want to do this again, any help would be greatly appreciated.
