Which rear gear is better?
  • 3.73
    Votes: 10 90.9%
  • 4.11
    Votes: 1 9.1%
1 - 11 of 11 Posts
Is it worth spending the $225 on a 3.73 gear set to switch from 4.11s
4.11s suck on the highway with a th400 trans
I'm on a budget OD trans is out of the options because I can't afford to build a 600 hp OD or get a 5/6 speed manual.
How much a difference will switching from 4.11 to 3.73s make? Both mileage and loss in acceleration?
I have 225/70/15 rear tires
I can't go any higher because I have a stage 4 eaton posi unit, the highest are 3.90s but I can buy a special 3.73 gear set that has a thinner ring gear to fit inside the stage 4 carrier. A stage 3 carrier would be ~$450.
I would like to make driving on the highways a bit more bearable going 65 mph
Is it worth getting 3.73s over 4.11s on the street?
If it's not going to make that much of a difference I won't get them
John
I'm sure someone will pipe in with the rpm's @ 60 mph. but I would guess there won't be enough of a difference unless you go to 342's or 331's.
I'm running 342's with tb400 bb & I wouldn't want to go any lower. good luck.
hmardown
Going from a 4.11 to a 3.73 will not make much of a difference. I have a 3.73 rear and it's pretty bad even at 60mph. You probably won't get a noticeable mileage increase, but you also probably won't be able to notice a performance loss either.
I would just save up for a t56 w/ .5 OD in the future. Or if you want to keep the auto then save up for a built 200r4.
If you want to get a noticeable decrease in rpm, and gain 1 or 2 mpg, then a 3.55 is probably your best option, but you would need to find a used 3 series carrier from a junkyard and you would probably see a slight decrease in performance at the track.
Gold Founding Member
Hi John,
I agree with Freddie. Either keep the 4.11s or purchase an Eaton 3 Series Posi and 3.42s. Make sure that you use a Timken Master Kit. I get good pricing on them.
PM me if you need any help.
I am not a fan of the thin 3.73 Ring Gear on a 4 Series Carrier. However, if you want to put a thick 4.10 Ring Gear on a 3 Series Carrier, that will make a strong 12 Bolt.
You really need to go to a 3.53 or 3.42 to see a noticeable difference in the engines rpm at 60 mph.
Anything less is a waste of money and time IMO.
Larger tire diameter helps slightly.
What power are you putting to the gears? If it is relatively low torque engine, the 373'S may still be fun. If you have a decent torque maker in a BBC, going to a 342 or 331 will still provide a good feel while slowing the rpms a lot.
Not worth the trouble and expense. Save some more money and get a 3 series Eaton Posi and go to at least a 3.42 gear. Don't forget that you will need a good installation kit to go with this.
I was also thinking 3.42....
1 - 11 of 11 Posts
