I own a 69 ss with 396 and 4 speed. There is an electrical switch attached to the clutch petal. The plug id not connected to anything. What is this switch??? Thanks
At what point does the switch work?
If it's when the clutch pedal is fully pressed it should be a safety start switch, if when you just start to depress it it could be for a cruise control setup
It is for the clutch to be depressed when you start the car. There should be two heavy purple wires, like 10 gauge, and will only make contact with the pedal fully depressed. Cruise was not availible with manual trans until later.
