Swapping rear end gears and possibly the tranny from TH350 to something w/Overdrive
Ok, I need some simple answers here. This is my dilema:
I am running a 71 Chevelle with a 350ci and a TH350 tranny. Tranny has a 2500 Fireball torque conv. and is a 3 speed automatic. Came original with the car. It also has a 10 bolt uni rear end with I think 3.55 gears.
I want to convert to a higher gear say a 3.73 posi unit. I am also aware that putting that ratio of gears will bring up my RPMS and as this is going to be my daily driver in the summer and i will be doing some hiway travelling and long trips, this will not be good for gas mileage. I was told that I could replace my tranny with one that has an overdrive to help bring down the rpms on the highway. I am also disapointed that after paying close to ten grand to get my engine completely redone with all new parts, it is putting out close to 400hp at the flywheel and I cant even get it to chirp the wheels from a standing start. The engine runs like a top and it has had my mechanic go over it with a fine tooth comb to tune it almost perfectly. The problem does not lie with the engine or its setup.
My questions are as follows:
I want to keep my automatic(my mind is set) and convert to a 3 speed with O/D. I dont plan on drag racing. (I may take it to the track once just to see its performance times).
What is the best/simplest swapover/cheapest/most reliable type tranny to replace my TH350 with? (The least painful switchover would be prefered).
Will I have any problems with kickdown brackets, other parts, shifting problems, or anything else that will have to be modified?
I know I will likely need to get my driveshaft shortened or vice versa so I am prepared for that, but will my 2500 Torq. Conv. from my TH350 fit onto my replacement tranny or is it specifically made for the TH350 only?
My budget is tight so I want to do it properly but not if its gonna be one big nightmare running around finding extra parts that I need and also spending weeks and weeks fine tuning the damned thing. My patience level is not as high as the average joe.
Any help from you veterans would be appreciated.
Thank you.
Thank you.
