I am doing a complete rebuild on 69 Malibu convert suspension. I want smooth, tight, ride. Polygraphite for upper, lower arms front, upper lower control arms rear, rubber everywhere esle. Stock springs and shocks. Any help or ideas? Thanks, Zetty
you might want to use rubber bushings for the rear upper and lower control arms. A lot of people say that the poly's are so stiff that they cause the rear to bind.
I just put poly's in mine and the rear is really stiff. I'm sure a lot of it is beacuse of the aftermarket springs, shocks, and sway bar, but some is probably the poly bushings.
If you want a more elaborate explanation of this, see Global West's site. They also recommend no rear sway bar.
http://www.globalwest.net/1964-72%20A-BODIES.htm#Rear Tubular Control Arms:
Charles Perrell
[email protected]
65 malibu SS Convertible
283 2v powerglide
<BLOCKQUOTE>quote:</font><HR>Originally posted by cperrell:
<HR></BLOCKQUOTE>
Thanks for your help, I cked the Global web and sent them an e-mail.
