What causes the lights to grow brighter then back to normal then brighter...then back to normal?
Its like it has voltage surges if that makes any sense.
Thanks,
Dwayne
All lights or just some?
73 Malibu
400ci 425/470
TH700-R4, 3:42 posi
Lovin my afr 190's!
Definition of an expert: Someone who knows more and more about less and less.
If they pulsate at a steady rate, especially at idle, in gear, it's your mechanical regulator cycling. The easiest, quickest way to eleminate this is to replace your old mechanical regulator with a Wells electronic unit. VR715 is the number, if I recall. Had the same problem until I swapped over to the Wells unit about 4 years ago. AND, it's only around 10 bucks, and is a direct "plug-in" replacement. Just be sure that the mounting legs are grounded to the radiator support.
MalibuJerry350
TC Member #1279
Original owner '70 Chevelle.
597,000 miles on car.
Hey, if it's got wheels, DRIVE IT!
My Chevelle: http://hometown.aol.com/erie614/myhomepage/index.html
[This message has been edited by MalibuJerry350 (edited 01-30-2003).]
MalibuJerry is dead on the money, my '70 Cutlass did the same thing and the Wells regulator solved it for $10 and five minutes of time. They are available at Auto Zone. They don't have points like the OEM ones but are electrically controlled.
Discussion Starter #5
Thanks fellows,
I will try the Wells unit.
and to clarify it is all lights... dash, headlights, etc. and is not really a steady pulsating surge but more of a random thing occuring several (say 12 times) per minute.
Dwayne
Two Cool Guys & A Muscle Car
68 SS Chevelle 396/325
69 Corvette 427/390
71 Malibu 307
See Em Here
"You will keep him in perfect peace whose mind is stayed on you"
