When I purchased the car it had a new headliner without sun visors. I just purchased a set of visors and really don't know how to install them. Are there any pics that show how this is done? My fear is cutting into the headliner and messing it up to install them. Any help you can give me would be much appreciated.
In Memoriam
fell around on the headliner in area where they usually are. there will be a flat plate with a centered large and 3 small screw holes. You should be able to feel this through the headliner. Cut a slit across the large hole, poke holes in the three small holes.
Get you a pick too as it helps tremendously to help you locate the other two screw holes once you have one screw going...don't let the screw driver slip off and tear your new liner or break the windshield...I've seen it happen and it isn't good at all...
