I bought new sun visors (that do not include the brackets) and was going to use some nice used chrome brackets. Except I can't get the rod into the bracket without tearing the bushing. I even broke one bracket trying to open it up with a flat blade screw driver.
Are the rods in the repopped visors a larger diameter than original? So what's the trick to putting these together? If I lube the rod, will it tend to let the visor fall down? (no lubed rod jokes
Doug,
I had the same problem on my 1969. I have come to believe that the word "repop" actually means "some rework will be required".
The way I got mine in was I put the bushing on the end of the rod and used a little white lithium grease on the busing. Then I layed the chrome brackets out in the sun in the driveway for about an hour. After I installed the visor in the car and tightened the set screw on the bracket they stayed in place just fine even with the grease on them.
Good luck,
Bill
Doug,
Like you, I broke one of my visor brackets trying to pry it open. Anyway, after purchasing new brackets & bushings and putting everything together, I couldn't get the brackets tight enough to keep the visors in place. I ended up cutting a piece of plastic soda straw to length and put in with the bushing. It provided just the additional thickness I needed to make the visors work perfectly. May not be as the factory intended, but it worked.
