If you look around on the net at Sun Blue Line gauges, there is a temp gauge and it needs a sending unit. I don't believe it's compatible with the stock chevy unit but has its own....
What is the sending unit that can be used with a sun blue line gauge?
Where can you buy them?
Super Moderator
Shane,
Which gauge is it ? You will have to find out what the resistance range of the sending unit is and find one to match. The gauges with a short throw usually use a different sender than the ones with a larger throw.
Do you already have the gauge ? Any gauge I have ever purchased came with a sending unit if it was required.
