If your running as mild 350-400hp setup with little to no strip time/no abuse i dont see any reason not to use the summit gearset if they are properly instralled which is critical when it comes to ring/pinion longevity.
But if your runnig a hot setup /nos/ along with abuse at the strip why take the chance on the cheaper gear set.
Scott
But if your runnig a hot setup /nos/ along with abuse at the strip why take the chance on the cheaper gear set unless you find out through research that Richmond supplies summit with the ring & pinion gear sets .
Scott
