1 - 20 of 68 Posts
I forgot to order a clutch pilot bearing when I placed my last order. Is anyone going to be placing an order in the next couple of weeks??
Kevin
Kevin, Car quest carries them at Frontier village. I can give you the part number. They stock one as I needed them every so often. It's the needle bearing one, I won't use brass myself.
Car Quest #57080
I am but your on the other side of the earth:D, plus it looks like you got it handled. And your really gona do grinding on the Brodix heads? I wouldnt if they were mine.
I would!!!!! :D
Actually, I got to drool on Kevin's Brodix's and there are some areas of clean up that will help. Nothing major. Just transition clean up from the CNC to the as-cast has some ridges.
I would!!!!! :D
I think you have a little more experience at that kinda thing that I do:D
Couldnt the dremel catch into the aluminum and start digging real fast on ya?
Thats ok Brian there not yours:D If you looked at the intake and exhaust bowls you would:yes: There is atleast 10-20 HP in there:D
I use a die grinder with a carbid bit. You just need to be gental.
I have an order but you are too far north,,,,
long Hemi Super Turbos, rear drag shocks, rings
I'm so pissed. Went to 3x parts stores that have a rep for having stuff....nobody carries rings! Not just rings for me but rings at all! All warehouse! One engine builder shop had none...but std would be odd for a builder shop.. Thinking Summit for these...
1 - 20 of 68 Posts
