1 - 20 of 21 Posts
· Banned
hello
at what point is it best to add a girdle to a set of heads..
looking for info.. like rpm
spring pressure /etc
solid any different that hyd..
roller to flat
thanks for your time
I don't believe there's any specific #'s involved. Just general ballpark guidelines. Personally, I wouldn't use a stud girdle on any flat-tappet setup, hydro-roller, or "street" solid roller. Just make sure you use good 7/16" studs.
You should always use them on aluminum heads,They will flex trust me.
When a rocker stud breaks at 8500 rpm you will wish the girdle was there to at least try to hold the stud in place.
It's pretty impressive what a rocker arm can do when pinched between another rocker arm and a set of $375.00 valve covers....:yes:
cam is
.660 intake
.660 ex
lift
248 intake
254 ex
duration
on a 110 sep.
solid roller
He's not gonna be turning 8500 with that cam. :noway:
Making sure you have the matching valve springs may be the single most important item.As Bob said,girdles are a PITA.
Guy
im a belt and suspenders kida guy so i went with them. i also cant spell. Dave
I had 3/8 studs with my solid roller, and I found I was losing valve adjustment. I installed a Moroso stud girdle the one with the U bolts, and it was easier to adjust my valves and they stayed adjusted longer.
Dave
When I first started adj. valves with a girdle it was a hassle but for some of reasons already mentioned plus a few more I'm glad I learned to adj. with girdle cause now its a piece of cake! Really! Anything less than 6000 rpm wouldn't use one but on a serious race application with rpm's up to 7000 and above use the girdle!
Bob
Warped, on a big block you don't take the girdle off and on cause of the valve angles.
I don't mind adjusting valves with the girdle.
One less thing to worry about, knowing that the stud and rocker are going to stay put.
well I was told I dont need them and my cam is close to yours a lil more duration on mine.
.660in/.630ex .270in/.280ex duration on a 110 lsa 106icl. I was also told to ditch the crower rev kit I bought builder said I wont need it plus I bought the worng one mines for regular roller lifters and mine are .300 taller isky red zones.
1 - 20 of 21 Posts
