1 - 10 of 10 Posts
I have a 71 chevelle, "freshen 350, 290 hp, 4 barrel, ac, at". Picked up the car in october last year, since then I have heard a ticking noise from the engine, especially when idling.
How do i fix? Is there some type of special lube I can use? I have had the oil and filter changed a couple of miles ago, no help. I was think about changing the oil and filter ago and adding a qt of slick 50. I have had very good results with this product when I was in alaska.
Any other suggestion?
I have heard the old schoolers say. Put a half a quart of tranny fluid in it and run it for 5-10 minutes. Then change your oil. I can remember doing this when i was a teenager and sometimes it worked, sometimes it didn't.
Any chance you can use a stethoscope to zero in on the noise?
Noisy fuel pump/loose rocker arm/exhaust leak at the head flange etc.
Is it running rough..tick under the dist cap or spark jumping to ground?
Just some things to consider.
Noise can be hard to diagnose over the internet.One mans clack can be another mans tick.
Doesn:t sound like a high mileage engine needing some marvels mystery oil to clean up sludge.Try to isolate the noise before removing the rocker covers.
Add some Marvel Mystery Oil or Rislone to the oil and drive for a couple of weeks. I have had good luck with both on used engines with stuck lifters. Throw that Slick 50 in the trash .
I agree. It could be several things.:yes:
1 - 10 of 10 Posts
