This is on a 350 w/HEI. Car will intermittently crank and crank and never fire. Then all of a sudden it will start, sometimes it won't and the battery dies. It does it maybe 1 out of every 10 starts, and there is no pattern. Sometimes when cold, sometimes just ten minutes after you shut it off. It has a rebuilt distributor and module. Car has had this problem for many years.
Sorry - I realize that wasn't the clearest post. What I mean is that you can crank the starter until the battery dies sometimes and it won't fire at all. Sometimes it will start normally, sometimes you can wait for a few minutes and it will fire normally as well. It has a B&M megashifter mounted in the floor. Originally it had a column shift, could there be something loose in the column that isn't being used anymore? What would allow it to crank but not fire?
When it won't start check for power at the HET BAT terminal while cranking. You could also tap a wire off the wire going to the HET BAT terminal, (add a fuse for safety) run it to the dash to a small bulb (like a 194) and then to ground. Check the bulb while cranking, if it is not on, the HEI isn't getting power.
One possibility cound be the IGN switch going bad or out of adjustment.
