1 - 2 of 2 Posts
I have removed my old somewhat cracked steering and have purchased epoxy,primer and black semi gloss paint and sand psper. I have sanded the entire wheel w/ 80 grit and need to know what is the next step to get a nice finished product. Thanks
You can look at the literature that POR-15 has on their steering wheel repair kit. The epoxy is the main thing. www.por15.com/faqs/faqputty.html
But I think a dremel or some kind of tool to create a "V" shape in each crack, then epoxy, (if you use the 2 part epoxy from POR-15 you can smooth it out with water = minimal sanding). Then I assume, final sand, and prep to paint.
Hope that helps.
DG
Springfield, Ohio
70 Chevelle Malibu
www.wright.edu/~adams.6/chevy.htm
TEAM Chevelle Member #0086
Genx member (Founder 4 Ohio)
[This message has been edited by DG (edited 11-10-99).]
1 - 2 of 2 Posts
