Got a 69 Malibu 350/ac car with power steering. Converting it over to a big block. Question is can I use that same power steering pump on a big block 454?
I think according to this tech referance you should be able to.It is a long list for BBC convert http://www.chevelles.com/techref/ftecref10.html
If you look at my pics the motor that was in there was a 396 with a 69 p/s pump.I have since put a 454 in I used my same 69 power steering pump.69 is a one year only pump and brackets mine were both big block.If you need more pics I can get my digital camera out just ask.As our cars are the same motor and year.Hope it works out for you:yes:
Jeff
Not sure on the pump, but the power steering brackets are different small block to big block. and are a one year only part, for a big block in 1969.
Now that I think about it, I don't think the pump is the same, and I'm quite sure they list a different pump SB/BB in the Ground Up catalog.
