Have 68 Malibu with non tilt, not column shift, steering column. When column was in the car, I noticed when accelerating and pulling on the wheel, the steering column shaft could be pulled back 1/4 inch or so. After taking apart I believe the problem to be the upper bearing and aluminum bearing housing. I can easily pull the bearing out of the housing. Looking at the housing bore there are ribs but some are wore. My questions are:
With the steering column on the bench, what keeps you from pulling the steering column shaft out of the steering column? Appears to me the only thing is the interference fit of the bearing in the housing.
Should there be a snap ring that retains the bearing in the housing?
Can a new housing and bearing be bought?
What are my other alternatives....JB Welding bearing into the housing?
Any help or advise would be appreciated. I am getting frustrated and want to get the car on the road. I can email pictures if needed.
Thanks a lot.
ANDY
Thanks a lot.
ANDY
