1 - 2 of 2 Posts
Hi all -
I'm in the process of disassembling a 70 tilt column, and need to remove one of the nuts on the steering shaft. It looks to be 1 1/8" in size, and the shop manual calls for a special thin-wall socket to remove it. There is no access for an open-end wrench. Has anyone had to remove this nut, and if so, what tool did you use? Thanks!
Rainer Seitz
Vancouver, WA
Team Chevelle Gold #50
ACES #3784
'68 SS396
'70 LS3 400 Malibu
'70 Malibu convertible 350/300hp
See them all at Rainer's Hot Rod Shop!
[email protected]
Rainer,
I had to remove that nut when I rebuilt my tilt. I bought a deep 1 1/8 impact socket and used the grinder on the outside until the wall was thin enough to remove the nut.
The manual calls for a special socket, what is the J number? Some of those J-tools are still available from Kent Moore.
Good Luck,
Jim Endrud
http://members.home.net/jimmy4/elky2.jpg
1 - 2 of 2 Posts
