The IROC box will be 12.7 to one ratio and less than 3 turns will shorten the spindle travel on a Chevelle causing less turning radius. The 77 Camaro unit will be 14.4 to one ratio and also have internal stops. Go to my site and read what I have discovered so far. Also check out jimmy's site for more info. There are bolt in boxes that can be bought from local sources for less money than the specialty suppliers that will help with ratio and feel. If you want a 12.7 ratio and use stock hoses you don't have pay the large dollars to those that sell them. It is easy to change the fitting on the back of the pump so you can use the "o" ring style hose and order a box for a Monte SS or Buick GN from 85-87.
Philip Valentine
Gold Member #42
Sometimes I think I understand everything, then I regain consciousness
Under Construction Car & Page
Philip Valentine
Gold Member #42
