1 - 2 of 2 Posts
:sad:I purchased the air ride tech: Street Challenge system STR 2001, but I am having some problems with installing the steering arm / knuckle onto the raise spindle that it came with. It seem that the old steering knuckle/arm has a leg on the end which hits the tubler control arm, which in turn will not allow the arm ( complete tire) to turn completly to side to side. I called a GM dealer, Jegs, OPGI, and Summit Racing, but they don't have a replacement. Do you guys have any input on this? There was a pic of the steering arm on the Air ride tech web page, and it looks like the leg on the arm is offset so it does not hit the lower control arm. Mine is straight. If you could please help with any info, or a part number that would be great! Also, does any one know how far the wheels turn right to left?
Are you seeing this with the front end in the air?
Geometry will appear different when the car is on the ground.
But I would not be surprised if you are limited steering L to R at the bottom or top of the suspension range with the air ride.
1 - 2 of 2 Posts
