I just put a new performance cam in by bbc. When i start it, it revs high than if i dont work the throtte it will stall. Its has a new 750 edelbrock on it also with a new rpm air gap. would the dist. be faulty, its a hei. Or is it the valves need set better.
Gold Founding Member
Is the choke adjusted properly?
Fast idle speed set properly?
Idle mixture screws adjusted?
Curb idle speed appropriate?
Initial timing correct?
Vacuum advance working? Connected to manifold vacuum; or to ported vacuum?
