Hello - I have a 67 with a 350. My motor cut out the other day and now will not start. I pulled the coil wire, cranked the engine over and see no spark. Could this be my after market coil(MSD Blaser 2)? Is there a fusible link, ceramic ballast, or other common area I should check - to diagnosis this no spark problem?
Any help on this matter would be very much appreciated.
Have you measured the voltage on coil (+) to ground? There should be around 8 volts on it with the key on. Don't leave the key on for a long time with the car not running. The coil will get hot.
