I had an issue with my starter awhile back, where it spun out of control and smoked, so I took the starter off and got it rebuilt, and since then I am having an intermittent problem where I only get a click, if I hit the key enough times, it eventually starts. I have cleaned up the ground where I have it bolted to the block, down by the fuel pump, I replaced both battery cables, and today I changed the ignition switch on the steering column, and nothing seems to fix it. After each change it seemed find a few times then its right back to clicking.
Anyone have any other ideas? I am getting so frustrated.
