OK I went to start my car last night turned the key turned over about one time and caluck good bye starter got under the car got the starter out looked at my flywheel that is know 3 teeth short. The problem is I have know whent thought 2 mini starters and two reg CSK starters. 1 mini starter and the Two CSK starters pretty much broke in half. All this has happen since I mounted my battery in the trunk last year. It seems It does this when the battery gett's a little weak and the starter doesn't disengage fast a nuff. Any idea's would be great. The only thing I can think to do Is try shorting the battery cable Maybe it's two long I could reroute It and save 2 feet. I will say last night I had a batter pack charging the battery so I don't know?
