I replaced my stock motor with a new one. I have a Accell distributer, no external coil, and a new high output starter. The starter has BATT, MOTOR, and SWITCH terminals. Assuming the BATT is the direct to battery positive and the SWITCH is the purple wire from yhe ignition switch what is the MOTOR? The starter instructions says that because there is no coil the R terminal of old is not used. Any help, we have replaced the engine harness.
Can't see the starter and don't know the brand but sounds like Motor is the connection to the starter motor windings. Much the same as the copper strap coming out of the original style starter.
Its a Powermaster Hi Torque. You agree with what I thought it was, Thanks
