What wires to the starter are removed after installing an HEI distributor. The hei has been working fine. Iam now removing the headers along with the headers came the starter. Now that the starter is down I would like to clean the excess wiring from the points dist. What goes where little help. Thanks
You no longer need the wire from the starter to the coil (yellow wire??). This wire supplied a full 12-volts to the coil when cranking (hotter spark?). Once the engine was running, the "resistor" wire provided ~9-volts to the coil.
Since the HEI uses 12-volts all thetime, you no longer need this wire... Only need the feed from the ignition switch to the starter (I think Purple wire?)
