I pulled my starter the other day and will replace it with a high torque mini from dbelectrical when it arrives. I will also replace the battery cables in hopes of curing slow crank when hot.
I am running HEI. The "R" terminal wire basically fell off when removing the starter, and is not needed in my application from what I have read.
I guess my question is, can the trip wire ("S" terminal) cause a heat soak issue? Should I replace the wire? Cover it in a heat resistant sleeve?
Thanks,
Matt
Thanks,
Matt
